remote start problems
I have a 88 eldo. and have recently installed a remote start system. Everything works except the accesory function, this means when the car is remotely started the acessories do not come on. It seems as if there is a wire that isn't connected to the remote starter. I have followed the instructions to a "T". Does anyone know something I dont about how to get the acessories to work. THANK YOU!!
RE: remote start problems
sounds like you need to take brain back to were you bought it?
Thank you for your response, however I have found out the problem for the remote starter. I found that the 3rd. ignition wire has to be connected to a relay because it sends a negative signal. When I followed the instructions on relay hook up, the accesories worked immediately! Any vehicle with a 3rd. ignition wire has to be connected to a relay to properly operate. The problem was'nt the product it was me! THANK YOU SO MUCH!!!
