Rear Suspension Squeaks
I recently purchased a 2002 Eldorado ETC from a dealer in Buffalo. 100 miles down the road the rear suspension starts to squeak and hasn't stopped. I sprayed every bushing I could see to no avail. Anyone have any suggestions as to what I should be looking for as a source of the squeaks? Any suggestions?
Thanks. |
RE: Rear Suspension Squeaks
I can identify with you. I recently bought a 2000 Eldorado ESC and it made creaking and rattling noises. I became obsessed in finding and fixing the problems. I was successful in getting everything fixed, but it took persistence.Read my post at the following link:
https://www.cadillacforum.com/m_1984/tm.htm |
rear airbags might br the problem, auto-leveling. I brought my etc for a front end alignment and the mechanic said "hope these never go bad" big bucks. Bring it back to the dealer.
As it turned out is was the knuckle bushings on both sides plus the hight hub assy. This seems to be a fairly common problem for this year and model. I hope they have re-engineered the part to last a little longer. It sure was a pricy repair.
Last Shot Auto Parts LLC 12048 Parklane St Mt Morris, MI 48458 1 (810) 441-7215 - main 1 (866) 365-4813 - fax lastshotautoparts@gmail.com Description Last Shot Auto Parts, LLC has for sale 2 PAT.PENDING Automotive OE Grade Cadillac Rear Knuckle Bushings. What you and other Cadillac owners are feeling isn't bad shocks,alignment,or tires. It's the rear knuckle Bushings. GET THEM ON EBAY MOTORS: http://motors.shop.ebay.com/merchant/lsapllc Here are Customer responses: "I can't tell you how thrilled I am to have these bushings available. I had them installed and what a difference in the handling and ride on my Deville. Your excellent customer service, and going the extra mile is refreshing in todays business world. Thank you, thank you, thank you." DAVE , Desmoines, IA 50311 Hello, "Thanks for manufacturing these parts, you save us all hundreds of dollars. I got your info on the caddy forum." Thanks for your consideration, Mike , Des Plaines, IL 60018 [IMG]local://upfiles/7490/CCB493E796E14582B36E29E8AFF21B69.jpg[/IMG] |
