Lower hose
Have a 2001 Eldo and need to change coolant out. What is easiest way to access lower hose please?
Thank you. |
The problem can be the clamp. I have clamp screw facing down so you need to be under car to loosen it. You want to put plastic over ABS unit it is not antifreeze friendly. Hose is serviced from the top. Removing drivers side cooling fan can be helpful for access.
Do any of these flushing systems work on the Northstar engines?
