Instrument Cluster Problem - 92 eldorado
I have a 92 eldorado with digital dash. The problem i am having is the cluster reads that i am on "E" (keeps blinking). Also my information center won't work either? And i know i have a check engine light on. But that wont come on either. Did anyone else have this problem before? I was thinking it was my cpu or a bad cluster. I search thought the whole forum and have found nothing on this topic.
mod edit title |
RE: Instrument Cluster Problem
ORIGINAL: BOSPLYA I have a 92 eldorado with digital dash. The problem i am having is the cluster reads that i am on "E" (keeps blinking). Also my information center won't work either? And i know i have a check engine light on. But that wont come on either. Did anyone else have this problem before? I was thinking it was my cpu or a bad cluster. I search thought the whole forum and have found nothing on this topic. . |
If your try to go in to On Board what happens?
How do you do that? I can see my oil life and gas mileage used.
ORIGINAL: slowroll If your try to go in to On Board what happens? |
ORIGINAL: stomper ORIGINAL: BOSPLYA I have a 92 eldorado with digital dash. The problem i am having is the cluster reads that i am on "E" (keeps blinking). Also my information center won't work either? And i know i have a check engine light on. But that wont come on either. Did anyone else have this problem before? I was thinking it was my cpu or a bad cluster. I search thought the whole forum and have found nothing on this topic. . |
On-Board Diagnostics refer to FAQ section.
i found out wat it was. it was the fuse under the hod labeled "SIR". I THINK
THANKS FOR THE HELP
