Eldo Aftermarket Stereo Question
Does anyone know where i can find a double din dash install kit for an aftermarket head unit? Also, where i can find a harness for the head unit? Thanks. |
RE: Eldo Aftermarket Stereo Question
i am doing the same i looked on ebay and purchased single din shaved it to fit my unit and it looks good if u have factory bose there is no harness
I have a 98 eldo which had the Bose system in it. I searched the internet and couldn't find the mounting bracket that looks plush with the eldo, so I went to Circuit City who was able to special order one for $28. As far as a wiring harness, if you have the Bose system, there is no wire harness. You will have to manualy bypass all the amplifiers. Make sure also when you bypass all the amplifiers that your remove the amplifier fuse which is located in your trunk. Any other question contact me at jluver777@yahoo.com
I also have a 98 Cadillac Eldorado Which i put an aftermarket Double din DVD
Player in Its a pioneer AVH-P6800 I had Audio Images Of Rochester MN Custom Make A dash kit for me which turned out absolutely flawless !! Heres there phone number I'm Sure if you call and ask them they could send you one !:) Let me know how it goes! Audio Images : (507) 252-8613 |
I couldnt figure out if I had factory Bose. I didn't see it writen anywhere on the books that came with the car or anywhere in the car. I took out the trunk carpet and on the right side I found an amplifier. If I have an amplifier does that mean its the Bose package, or is the amplifier in all versions. Thanks a lot
