Door panel removal
I was wondering if someone can help me remove the driver side
door panel on my 98 Eldorado? Thanks Ray |
RE: Door panel removal
Take a small screwdriver & gently pry the plastic trim off form the door handle.Then take a flat head screwdriver & pry up the rearof thewindow control panel.When it starts to lift up you'll see the metal lock tab on the rear of the panel.Push in on the tab & lift up.Remove the phillips head screw underneath.Take small screwdiver & gently pry out on the upper rear corner of the carpet trim on the door.Make sure you've got the screwdriver deep enough as not to seperate the carpet from the backing.It will fold out when you've pried the corner out.Behind the carpet is a small hole,there's a phillips head in there.Remove the screw & the liftup on the door panel & remove.
