Bose upgrade
I have a 96 Eldo with the standard Bose system. The last Eldo I had was the hiigher end system which had loads of base.
Is the a way rather than installing a sub woofer that I can up the base? I have the base up all the way and fade more on the rear but it's still weak. Can I install the high end Eldo factory amp with this system? If so is it difficult? Thanks Tim |
RE: Bose upgrade
ORIGINAL: projtim I have a 96 Eldo with the standard Bose system. The last Eldo I had was the hiigher end system which had loads of base. Is the a way rather than installing a sub woofer that I can up the base? I have the base up all the way and fade more on the rear but it's still weak. Can I install the high end Eldo factory amp with this system? If so is it difficult? Thanks Tim |
