99 ELDORADO FUEL PUMP ACCESS PANEL???? OR DROP THE TANK???
I HAVE A 99 ELDO ETC, IS THERE AN ACCESS PANEL THROUGH THE TRUNK OR DO I HAVE TO DROP THE TANK??? IF THERE IS A PANEL...WHERE IS IT AND EXACTLY WHAT DOES IT LOOK LIKE???
THANKS |
RE: 99 ELDORADO FUEL PUMP ACCESS PANEL???? OR DROP THE TANK???
You will have to drop tank.
Make sure you have the proper tools to discount the lines I messed one up , what a night mare !
here's how to drop the tank to change sending unit / fuel pump or inspect for leaks :D
