97' Eldorado coolant flush tabs
Hello I'm new to the forums I've seen a wealth of information I have a question hope to get some help. I had my coolant system flushed I don't believe the shop used and coolant sealing tabs when adding the new coolant. I've driven maybe 30 -40 miles at most would it be safe to add at this point 3 tabs to the system or shall I have to do a full reflush? should these 3 pellets have been added at the time the service was performed? thank you
GM cooling tabs do two things lubricate and protect water pump seals and seal small coolant leaks (seeps). GM information stated anytime coolant is drained from engine, tabs should be installed to prevent water pump failure.
Originally Posted by slowroll
(Post 53369)
I put them in when I redid my Eldorado and on the instructions it say to add them into the lower radiator hose...just a FYI
Originally Posted by kickasscadillac
(Post 53377)
http://www.rmi25.com/wp-content/them...SizedBlack.pnghttp://www.rmi25.com/wp-content/uploads/image/014.JPGhttp://www.rmi25.com/wp-content/uploads/image/logo.jpg Cleans Inhibits Lubricates Conditions NON-TOXIC AND BIODEGRADABLE Welcome to the official website of Nevada Coolant, LLC, makers of RMI-25. RMI-25 restores the additive package to your antifreeze. RMI-25 is a liquid consisting of a pH Stabilizer for acid/alkaline balance, an Oxygen Scavenger to prevent cavitation, erosion and cylinder pitting. A Lubricant for seals, hoses and water pumps. A Cleaner that breaks down rust, scale and corrosive deposits. These deposits are changed from solids to a soft floating harmless gel-like material. These dissolved solids will not recombine or form blockages in the cooling system. After a period of time the dissolved solids will purge out of the system and into the coolant recovery tank. In the case of vehicles with coolant filters the dissolved materials will trap in the filter. In a couple weeks of driving, a dirty system will be nearly clean. This cleaning action is continuous when engine is in operation. Once clean metal status is reached an organic barrier is then formed on the clean metal preventing further contamination. Water Conditioning is accomplished by a surfactant agent, improving heat transfer, making water more efficient than coolant itself. http://www.rmi25.com/wp-content/uplo...ge/bottles.png If you’ve got more questions, please take a look at the product details or the Frequently Asked Questions. For you gear-heads out there, you can also check out the tech specs page. The official website of Nevada Coolant, LLC, makers of RMI-25 |
Yeah I used the orange Dexcool and Distilled water. The instructions tell you to pulverize the tabs into a powder and then put into the lower hose.
