94 Eldo OVERHEATING!!!!
Hello everyone I'm new to the forum and I love the way people here help out one another, much love is here!
But I have an major issue wit my 94 Eldorado. Ok its overheating badly. First I took it to a shop and they had me replace the radiator, water pump, thermostat, and had my engine flushed! and I left I thought it was running great til I seen the dash said that it was running hot again. So, I let it cool off and put water back in it. Now, after that the heating coil went bad, so I disengaged that for I can drive it again thinking I know the problem and it still overheats when I drive it. I can drive 30 minutes without it saying you need to check the antifreeze or add antifreeze, then it runs hot again! So PLEASE I love my car, and I want it fix badly without me replacing the engine, or heads without it been too expensive.. Anybody have an idea's what they think the problem is I would greatly appreciate it, god know i would!! Thanks alot! |
RE: 94 Eldo OVERHEATING!!!!
Unfortunely it sounds like blown head gasket(s)
Do you think that heal a seal work? just wondering?
I don't think so, There are some products out there that claim to be the miracle cure, however I have not used any of them. Do your homework before using them. If you decide to try one make sure it is northstar compatible.
Will do! Thanx SlowRoll!
