01 etc door panel removal
I searched but found no reference to eldo inner door panel removals.
RE: 01 etc door panel removal
To remove the inner door panel pry up the push buttons and disconnect, You can do this with a small pocket screwdriver. Make sure that there is no philips head screws visable anywhere (lower corner of door panel, behind door handle, etc.) then push or lift the door panel "up". Do not pull it away from the door, that is what broke your clips in the first place.
Hope this helps. |
