is this normal on the caddy - Stabilitrac service stability system SYS
a new message just showed up on the message center saying( service stability system SYS) is this normal ? or something has broke ? and is there away to clear the message from computer
this usually is something you want to have looked at since the suspension is electronically controlled. There may be a sensor that has failed triggering this message.
I would agree with 92_Daddylac. The Service Stabilitrac message would mean that you need work done on this system to keep your vehicle in tip top shape. I hope that helps to answer what the message entails.
Jeff Morris, Cadillac Customer Service |
pull the code
