water pressure
The pressure in my 2001 devilleradiator is not very much.There is not much pressure in the radiator hose , it can be squssed pretty easy. Dont seem to be loosing any fluid,dont run hot. any ideas. havent had the cap tested yet but the seal seems good. thanks
RE: water pressure
I really would worry about it, as long as coolant level is full and engine is not overheating. Pressure builds up as coolant heats up. Cap should be 17 psi
RE: water pressure
Don't want to speak for slowroll but he means "really wouldn't worry about it." Ditto for me, you can squeeze the rad hose on most cars, just try someone elses.
RE: water pressure
I meant when the engine is hot!
RE: water pressure
Don't worry about it, life too short.
