upgraded cooling
Has anyone here modified the cooling system of their 4.6L machine? I have a rig that runs 10-15 degrees hotter when towing than the standard ~106 degrees water temperature the Concours sees normally. If there is a cross-platform radiator or separate transmission cooler I can run, I would be glad to do it. I tried searching the forum already and although there is a lot of great advice here, I can see that I may be running a bit of an odd setup.
Thanks in advance for any advice or tips you all can offer in terms of additional cooling ability. -NetJustin |
