stalling
'97 Deville, runs great until at a stop , a few seconds it dies but will restart each time. Dealer checked and found zip. Help!!
RE: stalling
Here are a couple things I have heard of to check in situtations similar:
Check the fuel pressure regulator. Supposedly this is something that is easily replaceable and costs about $70. I have also heard that if the fuel pump goes out, something within the whole fuel system will allow the car to get fuel while it is running. I don't remember exactly how this works but just remember reading about it. I would also replace the fuel filter. Maybe it is restrictive enough where fuel can't pass through it efficiently. Hope this gives you some help |
RE: stalling
This happened to me with my '99 Deville the day after I bought it. Exact same symptoms. Turns out it was the crank position sensor that was the culprit. Easy fix so check it out.
RE: stalling
are you still stalling
my 97 with 145,000 miles wanted new plugs & wires I was told they were replaced @ 98,000 but found that to be a lie when I changed the wires |
