how to change starter on 01 Deville
I have a 2001 deville and I believe my starter is going out. I was wondering how hard this is to replace, as I am not an experienced mechanic. Any information on this would be a great help. Im new to the forum as well. Thank you in advance!
RE: how to change starter on 01 Deville
ORIGINAL: CoupeDevillain I have a 2001 deville and I believe my starter is going out. I was wondering how hard this is to replace, as I am not an experienced mechanic. Any information on this would be a great help. Im new to the forum as well. Thank you in advance! why do you believe that? mileage? are you prepared and skilled to pull the intake manifold ? . |
It has 113000 miles on it. It makes a long grinding noise before it turns over sometimes. It seems if I put the key in the ignition and start it immediatley, it has no problem. Its not till i put the key in and what a few seconds it seems to have some trouble. I dont know if im imagining this. Thanks for your help.
ORIGINAL: CoupeDevillain It has 113000 miles on it. It makes a long grinding noise before it turns over sometimes. It seems if I put the key in the ignition and start it immediatley, it has no problem. Its not till i put the key in and what a few seconds it seems to have some trouble. I dont know if im imagining this. Thanks for your help. You may want to get a 2nd opinion. . |
