f 80 or f.8.0
My 91 caddy started running rough today.
I am not getting black, blue, or white smoke at the rear. Timing light lights on all 8 wires Gas mileage went to hell All seams to be in order with the the fluids Small squirts of starting fluid around the top of the engine produced no signs of an air leaks The only thing I can get out of the climate control unit is "f80" or "f.8.0" Any help would be appreciated Thanks Chris |
RE: f 80 or f.8.0
Any help?
thanks Chris |
RE: f 80 or f.8.0
If there are no E codes then you should start with the basics: Fuel, spark, compression and timing.
I usually inspect all spark plugs when investigating an engine performance issue. F.8.0 is BCM data , it shouldn't even show up until ecm codes have been displayed |
