error code E30 need help
i was out crusin this last weekend got pulled over by the highpow lol and before i left i fugered might as well check the codes while i was stoped and E30 came up along with E28 i know that one allready could the E28 through the E30 or are they seperate probs thnx brick
RE: error code E30 need help
How fast were you going? I am seeing RPM Out of Range. Did you actaully red line the Deville? WTF?
E30=Idle Speed Control Circuit Problem. Some switch is out of adjustment: TPS/Power Steering Sw/park or neutral safety sw. Out of adjustment minimum air rate, ISC/TPS can cause ISC not to control idle. E30 could also be a false code Long diagnostic 'tree' to follow.....
ORIGINAL: Dave S Texas E30=Idle Speed Control Circuit Problem. Some switch is out of adjustment: TPS/Power Steering Sw/park or neutral safety sw. Out of adjustment minimum air rate, ISC/TPS can cause ISC not to control idle. E30 could also be a false code Long diagnostic 'tree' to follow..... |
87 sadan and how fast does this car run by the way just woundering digital speedo stops at 85 thanx
87, ya Dave S Texas is right, sorry. On the top speed, I'd say 120 mph.
