driver side power seat quit working
Help..............I got into my car with wet clothes.....now my power buttons do not work my driver seat... what happened and how do i fix it?????? i'm riding in a reclining position.....not to cool.....
kgn |
RE: driver side power seat quit working
I suggest checking the fuse. Your owner's manual will tell you where it is and provide a diagram. I am not completely familar with your car but I believe the fuse block will be underhood near the air filter housing. You may also check to seewhat else may not be working to help pinpoint a fuse problem.
Hey KGN: If you find all the fuses fine as Katsman suggests then try and spray some wd-40 into the switches. This will replace the water and the electrical connection should return.
