code concern
got a concern?went to check my codes n it says,my system or engine is too lean, what exactly does that mean , and what Can i do to resolve this issue?appreciate it fellas...
RE: code concern
ORIGINAL: dhsman got a concern?went to check my codes n it says,my system or engine is too lean, what exactly does that mean , and what Can i do to resolve this issue?appreciate it fellas... |
RE: code concern
the codes are..po171,po174..my check engine light is on!when i put sumfuel injection fluid in it, the light went off for a while...what should i do
RE: code concern
Most likely plenum (rubber boot) between intake manifold and cross over is split. also check for other vacuum leaks.
RE: code concern
oo ok,thks guys,apprecciate it greatly, so how much will all this cost me and every thing,im tryin to get her n great shape!
