Check engine light
my check engine light in the upper left hand corner comes on occasionly but it never stays on the car is a 1991 deville with about 70,000 just wonderin if there was any ideas to what it may be cause it doesnt seem serious it just annoys me
RE: Check engine light
without any codes i can't tell you. your best bet is to call around autozones in your area and see if they have a scanner for your car and that year. autozone's the hookup, they do a free diagnostic on everything
thanks but what codes do u mean im sorry im new at this
i'm not sure how to pull the codes up for your car. someone else would have to answer or you might as well go to AutoZone like i said and they'll tell you better in person what you have to do to correct the problem - for free.:)
As a matter of fact i just got a code today when i had a full car and i put the pedal to the ground. I got P036, i read that the EGR is not in place or but i dont know what that means. Can anyone tell me what the P036 is and how to correct it ?
bump
the codes are information your engine gives techs to figure out what is happening with your car. for example you'll get a series of codes if your battery dies or is disconnected fully for more than a few minutes. this is just to let you know stuff thats happened in the past to different parts of your car, or what is happening currently. this is the difference between a history code and a current code.
as for pulling up yours i can only tell you based on my model, which is a 94 deville concours. i have to hold both the OFF botton on the econ control cluster and the "warmer", or HEAT UPbutton at the same time. this'll light the whole instrument cluster on your dash up, then start spittin codes out so be ready with pen and paper. come back and post what codes you got after you do that |
I got P036 on my 95' ETC, what's that supposed to be and how is it corrected ?
PO 36 is EGR valve pintle position out of range.
