A/C not blowing thru front?2003 Deville
hello all,bought a used 2003 deville,air blows thru bottom and front windshield defrost but not thru front on dash??? every now and then it blows ok thru the front how it should then stops??? i have no idea what it could be!!any advice is appreciated,thanks for your time,Isaac.
it sounds like a mode actuator but it also could be the control head
does it blow in just the bottom ----both sides drivers side and passenger side? does it blow out the side vents? does it blow out the defrost? all single not joint blowing? try this to recalibate the actuator
Ipcm??
air blows thru all spots except dash a/c,defrost is ok,side vents are ok,bottom is ok..defrost and bottom blow at the same time..where can i find the Instrument panel control module?? i just bought this car,and am learning as i go..all help is VERY appreciated!!Thanks.
as it changes from floor to dash
do u feel any out the vents it almost seems like the centre vent is missing on a/c it blows out the side vents correct if u put your head on the floor driver side u could actually see the door lever move |
when swithing from floor to dash,i can hear something move in the area of the dash where the vents are,but no air flows thru...almost as something is stuck.
well look under the dash and see if u see the lever moving
its may be a door actuator well there is one on each side but check driver side first then pull the glove box and u should see one behind there to if i remember correctly |
where can i find the positive voltage circuit fuse of the Instrument Panel Control Module???thanks.2003 deville
just remove the negative battery cable
wait and replace it clear codes and go same thing |
does this clear the codes?or do i have to do something else to clear??thanks
well ,this will clear some of them but it can also set codes
so u have to go through the section that tells u how to pull codes and clear them that way |
