ac problems 2003 deville
Ok so here is my problem i took a long road trip and on my way back home my ac stopped working everything was on i could see the lights on the dash for the air control but nothing was blowing out not even heat so i left it off and then like an hour went by and i tried it again and it came on so it worked fine the rest of the trip now the past couple of days its getting worse i try and turn it on it dosent come on i drive a little and try again it works fine some times i drive and then try and it wont come on i stop at the store go in come out and it works and i forgot to add i can hear the compressor kick and the back vents blow air but not the front could anyone please help me with this as it is very annoying not knowing when it will work and when it wont thank you much Edward
I've also head it could be a bad acm or actuator or a resister pack. |
