99 deville replacement mirror
Old 01-25-2019, 04:41 PM
Jeremy Sieger's Avatar
Default 99 deville replacement mirror
my baby was hit parked in front of my house. she is a 99 deville and i was unsure if it had heated mirrors or not. i ordered a mirror same color from a junk yard of a 98 deville with heated mirrors.mirror matched ok not perfect but only one of the plugs plugged in to the car. the power part works but the other plug i assume is the heated mirror does not fit together. the 99 is a 2 wire plug and the 98 is 6 wires.below are pics of what i have. can i cut plug off new mirrir and make it work or does it have to be mirror off a 99?
pics will not life for some reason
Old 01-25-2019, 04:55 PM
Default pics
pics?
Old 01-29-2019, 12:58 PM
so i think i figured part of the problem out. the mirror off the 98 has a auto dem
feature and is yellow color. it has a 6 pin connector. mine only has 2 wires for the defrost.
can anyone tell me what 2 wires out of the 6 pin need to be connected to my 2 pin connected to make defrost work?
Old 02-17-2019, 11:36 AM
Cadillac 1999
Deville side self Dimming fit over replacement mirror. It is suggest to glue this mirror over the old mirror for proper fit. If Mirror Turned Black or Brown, this is your mirror replacement.
Old 02-17-2019, 11:46 AM
Default thabks
Originally Posted by peter.handscomb
Cadillac 1999
thanks for the reply but not sure you understood my question. the mirror is not broken but off a different vehicle that had auto dem. mine does not so the plug on the car side has 2 wires and the plug on the mirror side has 6
caddydaddy1027
11-14-2008 10:49 PM
chadmack
10-28-2008 04:03 PM
mechanical man
04-14-2008 05:36 PM
rconn16
02-24-2008 12:37 PM
CJBennett01
11-05-2006 09:55 AM
Quick Reply: 99 deville replacement mirror
