94 concours obdII
I have a 94 Concours just did an engine replacement and found that the fuel injector harness got very hot at the plug into the main loom. I rewired the porblem and put in the engine now I have a rough idle and 2 OBDII codes 52 deffective ECM, and 109 PCM lost primary battery power. Can anyone help me with this?
RE: 94 concours obdII
The 94 was OBD-I not OBD-II.... But anyway, did you swap PCM's with the engines?.... I think I heard somewhere that you need to keep the same PROM chip with each engine... I'd have to look it up as I'm not sure though.
Krashed I did use a prom chip from the doner engine. Can you think of any thing else. How can I check if it has lost primary battery power?
Wait... LMAO I just looked up those codes for myself. You have nothing to be worried about.
P052 (E052) ----- PCM Memory Reset This is from the battery being disconnected while you were swapping engines P109 (E109) ----- Keep Alive Memory (KAM) Reset/PCM has lost primary battery power And this is also from the battery being disconnected. All you have to do now is drive it around. After a few drives it should relearn the idle automaticly and you'll be good to go. |
Krashed,
Thanks for the info. We have put on about 40 miles already. How many miles do you think it takes for it to relearn???? |
Miles don't matter... What matters is key cycles. Turn it on, go for a short drive, then turn it off and repeat... If that doesn't help you'll have to do some further diagnosis
Krashed,
Again, thanks for the help and I'll give it a try. I'll let you know if I continue to have the problem. |
Those codes have no effect on the engine sytems.
Just letting you know the pcm lost power since the last time the codes were cleared. A rough idle is a vauge description. Can you narrow it down to an individule cylinder? Does it seem like a misfire? Does it drive smooth? |
To me I thought that it could be a bad injector because I had to rewire the connector I really took my time doing so though. The part was over 700.00 at Cadillac. iIt will drive really good but then when you slow to a light the idle drops too low and starts missing I cant be sure the cylinder because it does not have a misfire code.
There is an idle relearn procedure... But I'm at college right now so I can't look it up in my FSM at the moment.
Just out of curiousity, does the ICM "click" repeatedly after you turn the engine off? |
