1992 Deville Radio stop working?
I have a 1992 Deville and the radio (has cassette player) went out. At first it was the sound...within a few hours the radio no longer turns on. It still displays the clock.. pushing the power and just the antenna goes up.
Can I replace the unit with one from another Deville or maybe aftermarket?
I'm not sure if the security ties into it.
It did sound nice and recently bought the car. I bought a Autozone Haynes Manuel and it said nothing of the security system.
any info is greatly appropriated.
Mike
I don't think it is a hi end radio...no Bose emblem was found. It does have a equalizer above the radio...if that helps out any. It all appears to be stock.
I haven't checked the fuses but....still I feel it no longer works...as I stated earlier the sound went out first....unless I am missing something. The wife currently has it at work.
this is the only picture I can find.
and a larger pic..here is the link. http://www.texas4x4.org/gallery/albu...IMG2370?full=1
Mike
Check fuses first. Most likely a blown fuse. Check under dash for a blown yellow 20 amp 'body" or "csty" fuse. Usually blows because a cell phone charger is used in the dash cigarette lighter socket or a piece of metal is in a lighter socket front or back. If its a Bose, no equalizer and the speakers will have BOSE emblems on them.
Check for blown fuses 1st, radio has 2 power sources both in fuse block under drivers side of dash.You can go after market with radio, I would suggest to get plug kit so factory harness is intact. There is a hidden screw to bracket on back of radio. You will need to remove ashtray assembly to access screw.
I have a 2002 deville and the radio stop working. I just got the car from the baby shop and the radio just stop working. I checked the fuses and the are ok. It comes on and cuts off the adio has a anti-thief in the radio are their any other fuses or problems
