1992 deville losing coolant
its loosing coolant quick but its not going on the ground and i can't find a leak, i don't think its a headgasket because it does not smoke and does not miss or anything so any ideas?? thanks
RE: 1992 deville losing coolant
Hate to say this, but check your tailpipes when hot. Had the same thing happen to a 97 that I bought. It was running hot and I could not see where it was leaking to. Had to be cracked heads running down the exhaust. Ditched the caddy and bought another one.
i ran it for about 30 minutes today and there is no smoke or anything coming from the exaust, when i take my radiator cap off there is a slimey green buildup on the inside of the cap, i was told it could be evaporating through the cap if it is bad, i don't know whats wrong with it
That's a cheap and easy fix, let's hope for that. That would be great.
put a new radiator cap on it and it stopped running hot and there is no more lost coolant, simple and easy fix, i'm glad too
