richard96 needs help on oil cooler
Originally Posted by richard96
(Post 34723)
'97 Catera 64K miles
:mad::mad: I have oil in my coolant resevoir. I use 1 quart a month. There is no water in the oil just oil in the water. I have flushed the radiator clean 3 times over 8 months. I also ran an expensive block sealer through the coolant system as well. I am guessing its an oil cooler problem. Not sure. Any help out there? Thank you in advance.
(Post 35119)
Any techs out there with advice on how to tear into this oil cooler?
Help please. I have barely enough money to buy parts. I could use some helpful advice to r and r the oil cooler. Thanks in advance, Rich.
Originally Posted by stomper
(Post 35123)
Catera almost same as CTS, right?
https://www.cadillacforum.com/forum/...ead.php?t=9853 .......... |
Originally Posted by stomper https://www.cadillacforum.com/forum/...s/viewpost.gif
Catera almost same as CTS, right? Not even close. You have a rebadged Opal Commonder.:( |
i found this somewhere:
CTS was designed as a replacement for the badge-engineered, Opel-based Catera. Originally slated to carry the same name as its predecessor, the new Catera Touring Sedan, instead became known as the CTS, otherwise called C-Series Touring Sedan. The success of the CTS has been attributed in part to the car's placement in the 2003 sci-fi action thriller The Matrix Reloaded, followed by the 2008 Motor Trend Car of the Year award. . |
