nnedrebo |
05-21-2015 09:45 PM |
Oil cooler lines.
Just had a question on the oil cooler lines that go to the bottom of the radiator. I was curious about how much pressure those line have in them? I bought a 03 cts and the guy had done some work to it and pulled the line out of the radiator on the passenger side of the radiator and it started to leak and then i took apart the other side and those line had been "repaired" using like jb weld or something so I think I may have to cut it at the rubber end and put it on the new one with a clamp. So just curiouse on the pressure in the line wether or not a clamp would be ok on it
