No A/C on passenger side.
Old 05-10-2017, 02:47 PM
springwater's Avatar
Default No A/C on passenger side.
I have an '08 CTS.
So the A/C on the passenger side stopped working.
I had someone check it with a scan tool and they said that the door is "sticking".
They quoted me a crazy sum to change the blend door actuator on the passenger side.
Is anyone familiar with the fuse reset procedure?
If that doesnt work, I guess I'll have to tear into the dashboard. Any DIY vids or threads on how to replace the passenger side blend door actuator?
Old 07-20-2017, 01:05 PM
wastintime's Avatar
Default 08 cts a/c
i have an 08 cts and thought i had the same problem. bought the new blend door but never installed it. a friend suggested that the freon might me low. so i added 1 can and the passenger side started working. that was a year ago and it's still working fine.
Old 04-18-2019, 01:28 PM
marcrinker's Avatar
I had the same problem. Added freon and it worked. I think the system is designed to direct the last remaining cooling to the driver if the freon is low.
Blaise
05-17-2017 01:24 PM
Blaise
05-15-2017 06:38 PM
gwchristopher1
10-18-2013 12:01 PM
scard
05-10-2010 11:39 PM
bowman1268
11-04-2009 01:38 PM
Quick Reply: No A/C on passenger side.
