Help needed
I have a 2003 CTS.
Few days ago i went to start it and the engine would not crank. Complete silence. All dash lights worked, headlights worked and did not dim when i attempted to start the car. I checked the following: Codes. Non popped up other that front window codes. Checked starter relay (swapped with blower relay) no luck Checked battery: 12.5 volts Checked connection to ECU. When i insert the key in the security with lock light goes out after a few seconds. -could it be the chip is faulty or de-programmed? I am running out of options The car does not crank or click. I turn the key to start and all goes silent. any thoughts? |
