CTS 3.6 automatic gear ratios
Can anyone tell me what the gear ratios are for the CTS 3.6 automatic transmission?
RE: CTS 3.6 automatic gear ratios
1st Gear Ratio 3.42:1 2nd Gear Ratio 2.21:1 3rd Gear Ratio 1.60:1 4th Gear Ratio 1.00:1 5th Gear Ratio 0.75:1 Reverse Ratio 3.03:1 |
What should be my RPM at 70 mph. Does this transmission have a lock up converter for the overdrive or is it a true fifth gear?
Not sure about the rpm, there are online calulators that will tell you.
Overdrive and lockup converter are two different things. Everylate modelautomatic transmissioni know of has both. |
