Coin behind ash tray HELP
I dropped a coin behind ash tray, every time I make a turn it moves and hitsa panel, I need to take it out. How do I go about it? |
RE: Coin behind ash tray HELP
ORIGINAL: kade7236 I dropped a coin behind ash tray, every time I make a turn it moves and hitsa panel, I need to take it out. How do I go about it? assuming you can reach them, try a wire wrapped with tape sticky side out. chances are that if the coins fit through a hole or a crevice, so will a wire. other than that, pull panels. add car and model to your signature and we will always know what you have. |
Originally Posted by stomper
(Post 28672)
chances are that if the coins fit through a hole or a crevice, so will a wire. other than that, pull panels. add car and model to your signature and we will always know what you have. today I drove hard, with sports mode on after I got out from work and started the car I have a check engine light on I restarted the car and it did not go away any idea I’m planning to go to the stelership on Monday |
