flutter noise on deceleration
Old 09-17-2017, 01:07 AM
racerjim's Avatar
Default flutter noise on deceleration
my V6 CTS has a flutter type noise any time I decal. It is not present at idle or at cruise. I have disconnected almost all of the vacuum systems to no avail. Any ideas? I have thought maybe the throttle body blades flutter at the closed position. Any help would be appreciated. racerjim
Old 09-27-2017, 10:54 PM
racerjim's Avatar
I have drilled tiny 1/8 inch holes in both throttle blades. My first road test revealed no more flutter noise. It appears problem solved !!
Old 10-03-2017, 09:36 AM
racerjim's Avatar
Well I am wrong. The flutter is back. Help Please. racerjim
Old 02-22-2018, 10:01 PM
racerjim's Avatar
I have found that the "dirty PCV hose" that I believe has a check valve in it flutters on decel. I removed it and road tested it, NO MORE FLUTTER NOISE I will try to find a replacement hose assy and move on to other things. I hope this may help others that have a similar noise.
04cavillac
03-25-2011 10:03 PM
9treseville
06-22-2008 05:41 PM
gmburd
10-05-2005 04:34 PM
stevel2
05-23-2005 09:43 PM
DHSDADDY
12-15-2004 12:23 PM
Quick Reply: flutter noise on deceleration
