2011 CTSV problem
Hello all. I am hoping I can get some assistance from you expert V owners. I own a 2011 CTSV Coupe. Just 12K miles on her.
No mods, everything is factory. The car has been towed to the dealer 3 times now. Symptoms are, engine light comes on, traction control light comes on, vehicle sputters/wont go or goes very slowly and sometimes has trouble even starting. Cadillac dealer changed spark plug wires, fuel pump and fuel pump control module all with no luck at fixing the problem. Dealer says diagnostic is throwing codes 171 and 174. Has anyone experienced something similiar or can someone give me some advice because the dealer is back to the drawing board? |
Update from dealer
UPDATE from dealer:
They are replacing the wiring harness that connects to the fuel pump, draining the fuel and adding 92 octane and replacing the fuel pump again. . Well see what happens this time.. |
Originally Posted by miller_v
(Post 44260)
UPDATE from dealer:
They are replacing the wiring harness that connects to the fuel pump, draining the fuel and adding 92 octane and replacing the fuel pump again. . Well see what happens this time.. Michelle, Cadillac Customer Service |
Originally Posted by Cadillac Customer Service
(Post 44262)
I hope these steps that the technicians are taking will get this resolved for you.
Michelle, Cadillac Customer Service Would you happen to have any suggestions as to the cause or have you seen these symptoms before? |
(Post 44267)
Thanks! I hope so too.
Would you happen to have any suggestions as to the cause or have you seen these symptoms before? These questions would be better turned to the attention of your technician. Since I am not a technician in any shape or form, I do not have access to the information as to the cause or symptoms. I apologize for this inconvenience. Michelle, Cadillac Customer Service |
Coupe problem
We had that same problem with a 2 day old 2012 CTS V Wagon. It was a throttle position sensor. Apparently many CTS V's are having this problem. They replaced ours and no problems since.
