2010 misfires multiple codes please help!!
Blinking engine light and bad misfiring led me to Renting a code scanner and got the following show up-
Cylinder 4 misfire Ignition coil d primary/secondary circuit System too rich bank 1 System too rich bank 2 Evaporation emission system high purge flow Cylinder 4 misfire detected I changed my plugs, coils and purge vapor canister then cleared the codes I started the car and it was running good again, went about a mile down the road stopped and went to thrn around and the car started misfiring and light flashed again . Now when I scanned this showed up - Crankshaft position camshaft position correlation bank 1 sensor b cylinder 4 misfire Evaporative emission system high purge flow System rich bank 1 Bank 2 cleared the codes again and the crankshaft sensor code dissapeared but the other 3 still remain and car is misfiring and running rough please help |
Sorry forgot to include what I'm driving, it's a 2010 cts 3.0 with about 160k on it
