Engine
Hi.
I have ha throttle problem with the 1972 472cid. Its like the engine trutters,...laks fuel or air.. it wont kick in right. The problems accours when the engine is cold and when the gass peddal is puched less than 2" down. The engine rersponds correctly (at least much more) when the pedeal is pressed beyond 2" towards the floor. Thx Rags |
Primary choke pull off or choke coil adjustment or failure.
I C,
Where do i find the choke coil. Iw oiled the pull, and it was pritty stiff. Thx Rags |
