66 windows only work on emergency
Old 01-31-2018, 08:38 PM
Kylebosch24's Avatar
Default 66 windows only work on emergency
just got my first caddy last week a 66 coupe deVille on bags and 20 inch mob steel wheels
my question is the windows worked perfect last week now nothing only when I use the emergency button on the emergency/normal/lock switch
what could cause this a fuse ? Thanks guys
Old 07-27-2020, 08:28 PM
65deville's Avatar
Put a test light to the fuses, make sure the ground is good. Spot blown fuses and replace them. Put a test light to the wires in the switch and the switch itself. Test the switch. You'll find your problem.
-paul
Old 06-24-2021, 05:38 PM
GRADS's Avatar
Bumping this. Did you ever figure out what the problem was? I'm having the same problem now.
Kylebosch24
02-02-2018 07:29 AM
Jeff R
05-18-2013 09:19 PM
lp1974ny
06-22-2011 08:48 AM
talldaff
02-01-2009 07:28 PM
PIMPDADDYCADDY
08-01-2007 05:53 PM
Quick Reply: 66 windows only work on emergency
