VATS key codes
complements of Rickko, Allante owner VATS key code of your key you need to read the resistance of the key. If you have a digital volt meter, set it on ohms mode and measure the resistance of the pellet on your key (touch probes to each side of pellet). Ignore the decimal place in the readout or switch to the correct scale. The BCM is programmed for a specific resistance value. The BCM measures the voltage drop across the key pellet. If it is within +-10%, then the car will start. The 15 resistor codes are: Key# Value (Ohms) 1 392 2 523 3 681 4 887 5 1130 6 1470 7 1870 8 2370 9 3010 10 3740 11 4750 12 6040 13 7500 14 9530 15 11800 . |
RE: VATS key codes
CODE RESISTOR VALUE IN OHMS
1996 GM Vats ( 1 ) 402 ( 2 ) 523 ( 3 ) 681 ( 4 ) 887 ( 5 ) 1130 ( 6 ) 1470 ( 7 ) 1870 ( 8 ) 2370 (9 ) 3010 (10 ) 3740 ( 11 ) 4750 ( 12 ) 6040 ( 13 ) 7500 ( 14 ) 9530 ( 15 ) 11800 |
