Installing PLATINUM plugs in a 1988 Allanté
Before starting you will need: 1. a SMALL ratchet .. no Ifs, no Buts.. a MUST! 2. dielectric grease 3. antiseize compound 4. 8 plugs, pn 41-902 AC Delco. The case is 8#41-902 ACDelco. 5. Primary wire puller 5. fuel filter 6. distributor rotor (if you need plugs, this one is most likely also ready to go) 7. Inspect Distributor cap - 8. Inspect primary wires - 9. Fender protection suggest blow/ clean or whatever is needed to remove debris from around plugs. I sprayed with engine cleaner and rinsed 1st, place a heavy blanket on the fender for protection. blind-inspect (using your fingers) the primary wires to determine if you will need a new one here and there (about $7 each) due to damage. Also inspect distributor cap. disconnect all the primary wires you can from topside at the plugs. Make sure you pull the boots not the wires. A puller is available for about $4. dabb connector ends of each plug with dielectric grease (AFTER installation) for moisture protection and apply a tiny bit of antiseize paste (BEFORE installation) on threads of each plug raise the car on the lift, and from underneath, remove the three REAR primary wires and plugs closest to the passenger side. that took about 10 minutes. ratchet and socket. installed three new ones. cannot reach the 4th plug from this angle. since car was up there, changed the fuel filter, by the rear drivers side wheel .. 5 min. dropped the car, removed the air-intake and duct all the way to the throttle body. Now you can remove the 4th plug from the top .. ratchet / socket and a 2 in extension. It is right by the side of ABS ac***ulator .. about 20 min, this one plug requires a bit of patience and you will basically have to climb and lay on the engine compartment to do it .. use that blanket to protect the fender .. installed new plug, 4th. installed air-intake and ducts and a new air-cleaner. made sure the primary wires are in their holder or the manifold will burn them. Apply dielectric grease to inside of each end of each primary wire (including distributor end) and then plug in all the wires to the spark plugs from topside. removed/replaced front 4 plugs, 5 min. Repeat the primary wire process. The old plugs were R44-LTS6 ACDelco, iron tips. hints? .. remember to do a blind inspect of the primary wires with your fingers and feel for damage or roughness .. one of mine was burned through by the exhaust manifold .. this is common on caddies. all this stuff i had read about changing plugs had me thinking all kinds of horrors, and posponing the job. none of that happened - no need to remove anything else. again, as you may know, i have a 4.1L .. Dont know if the same applies to a 4.5L. got frustrated of looking for the right plugs at the local part houses, so I went to the Caddy dealer, ordered a set of dual platinum plugs for a 1996 Seville, 4.9L. Got pn 41-902 AC Delco. Cost $60 for the set. Someone told me the Champions (about $10 less) are just as good .. I choose to play it safe on this one and went ACDelco. After all, these are 100,000+ mile plugs. They way we use these cars, these plugs may well go 200,000+ miles. So the cost is small if one looks at it this way. the fuel filter was $24. afterwards, checked the old one, it was fairly well plugged. just a matter of maybe a few more tanks of fuel would had given problems. so .. what is the trick? Only to remove the rear plug closest to the drivers side from the top. you must use a SMALL ratchet .. it pays to buy one if you don't have a small one. oh, one last thing .. on checking the distributor cap and rotor .. pull it off and see if the rotor shows signs of blackening in the backside center area, a sign of severe aging .. replaced it as this center is known to crack/burn through after aging starts blackening it and you will get a shut down on the engine. cost $5 that is it ... oh no.. wait .. did i mention you have to raise the hood lid? |
