Cadillac Allante Boch III ABS brakes - 1987 to 1992
Allante Boch III ABS brakes - 1987 to 1992 Important note on GM. - GM to date, has refused to recommend this procedure. Yet we, the Allante crowd, know without any doubt whatsoever, that the BOSCH III decays rapidly without this procedure. The system builds up crud, its effects magnified by moisture absorbed on the unsealed system. The end result being a failed ABS Master Cyl, a very expensive item often exceeding the cost of a car. Important note on brake fluid, DOT-3 or DOT-4 - The BOSCH III ABS - 24 months is the very max the fluid should be in the system before FLUSHING. i practice 12 months. - Fresh fluid has a cleansing quality that extends the life of master cyl ($900 rem, $3,000 new), ac c u mulator ($250 rem to $600 new), high pressure pump ($200). If your system is dirty, FLUSH more often as that in itself will slowly clean the system. The first time I flushed I continued the process until I used up the whole gallon. A lot of new clear fluid went in, a lot of dark cruddy fluid came out. Also, FLUSH the lines. - the BOSCH III is used in the '87 to '92 models. Not in the '93. - If i'm wrong on the maint cycle, i will spend an xtra $15 / year, if i'm right i will save from a few $100's to $1,000's in components. HIGHLIGHTS : - get a FRESH and SEALED gallon of brake fluid, DOT-3 or DOT-4 - you are going to need that much. - Know that GM & FORD do NOT require machining of rotors in a brake job, if the mechanic states that they do, ask for the instruction - there is none. - avoid machining rotors unless damaged and then it is best to replace with new ones, they are designed to be machined but you are at the mercy of the lathe operator ... - DONT forget the anti-chatter clips - Always OPEN the brake fluid drain valves BEFORE you retract the caliper pistons, - leave valves open until caliper and pads are back on rotor, bleeding air out is not anywhere as bad as replacing a Master Cyl that got fluid reversed into. - avoid at all costs back-pushing crud fluid, specially on the BOSCH III (1987 - 1992) , - FLUSH / BLEED brake lines at each wheel, same as any other GM car, - IF lines are original OEM, they are OLD - replace, - FLUSH the master cylinder, high pressure pump and ac c u m ulator ABS, (detailed instructions at Allantesource.com ) - know that the parking brake adjusts the REAR brakes .. - know that the parking (e-brake) also sets the RED ABS Light. CALIPERS: FRONT calipers - the C-CLAMP works well in retracting the front pistons REAR calipers - NO amount of pressing will move the REAR piston. forget c-clamps, you need a spanner wrench type of tool to retract the rear pistons, tool # K-D 3163, which is a little metal cube that attaches to a 3/8" drive and has lugs that fit into the slots on the pistons. Calipers are the same as equip used in many Cadillac models. * PADS, $45 for PREMIUM semi-metallic (Ferro-Compound), $25 for organic - PER AXLE expect to double that buying PADS at dealer * soft pads are easy on rotor, make dust, and work well cold * ceramic pads eat rotors, they dont make much dust, dont work so good cold * pads, from soft to hard ==> Organic, Ferro-Compound, Ferro-Carbon, Ceramic, Kevlar-metallic * new calipers, around $40 per. * new rotors, around $40 per machined thinner rotors may warp faster with lessened capacity to absorve heat. Brake Pads: "In addition to quality organic and semi-metallic brake pads, the ACDelco DuraStop line offers ceramic brake pads for even better performance." ( be aware that these are exactly that, performance and they wear out rotors FAST ) these are some of what Delco offers: BONDED 171-556 - PAD KIT,FRT DISC BRK 17D353M - PAD KIT,FRT DISC BRK DURASTOP SEMI MET RIVETED 171-557 - PAD KIT,RR DISC BRK 17D354M - PAD KIT,RR DISC BRK DURASTOP SEMI MET Anti-chatter/rattle clips: The kit is Bendix part# is H5590, GM part# 18060057 approx $8 /wheel DELCO PARTS SEARCH: http://198.208.187.182/internet/Vehicle.jsp?application=Car%2FLight+Duty +Truck&year=1988&make=CADILLAC&model=A LLANTE&engine=&selectedfld=model the DELCO BRAKE QUIZ: http://www.acdelco.com/acdelcoapp/te...zes/brakes.jsp it is believed that the rattle in the Allante brakes is caused by a change in size of the pads, including DELCO pads. read on .. Original by eldobro I went through this with a 91 Seville, which has the same set-up in the rear. I replaced all the bushings, caliper bolts and clips, but the rattle was still there. I wound up smacking the caliper with a rubber mallet and poking here and there with a screwdriver until I found the problem. The rattle didn't start until I replaced the original pads. I dug the old pads out of the shop garbage and measured them. I found that they were slightly narrower side to side. That and the wearing of the caliper bracket where they hang caused the rattle. There was room now for them to move around with the caliper when I would hit bumps with the car. I tried an experiment Using the new pads as a gauge, I had a new surface welded up on the caliper bracket and then cut down so the pads still had clearance side to side, but not enough for the caliper to build up momentum when I hit a bump. I put it all together, drove down a rough road and the rattle was completely gone. after all this time, the rattle has never returned. |
RE: Cadillac Allante Boch III ABS brakes - 1987 to 1992
Rainy season is here .. time to flush the '92 BOSCH ABS
from the archives of my '88 ... =========== Complete flushing the ABS BEFORE the brake job will of course take out a lot of the CRUD and reduce the chance of reversing any crud back into the system. However, even then, the bleed nipple valves should be opened before pushing on the calipers so any and all fluid will exit instead of reversing itself into the ABS. THAT is good practice in any car, not only the Allante. The more you flush, the cleaner your ABS gets, including the AC***ULATOR .. new brake fluid has the effect of cleansing and that is a good thing. FLUSH =============== Went to Dicks site printed the instructions, and went at it. this is what i did: 1. removed reservoir filter, 2. syphon as much as the fluid in reservoir as possible 3. fill reservoir with DOT 3, from new SEALED can, took almost a liter. 4. put cap back on, did not put filter back in for now. 5. then i started bleeding per instructions: Here is the procedure for manually bleeding (without a power bleeder or vacuum bleeder) the system after reinstallation. First the ABS pump gets bled, key on, until bubbles are gone. A clear hose gets attached to the pump bleeder screw, the end of this hose submerged in a jar with about an inch of clean brake fluid in the bottom. Open the bleeder screw on the pump, and let it run until it clears up. About 30 seconds at a time is all you should let the pump run. Let it rest for a minute, then another 30 seconds, etc. Generally three cycles of this will be enough. Keep the reservoir full, within 1/4 inch of the full line. that part went great! 6. Next step on the bleeding: Next you bleed through the bleeder screw on the master cylinder. Again, have a clear hose on the bleeder, end submerged into a glass jar with clear brake fluid. Open the bleeder screw. Turn the key on, and let it run until fluid is clear of bubbles. 30 seconds on cycle, then rest. ****** this part went to hell!!!!! ***** As soon as open the bleed valve, the fluid shot out, ripped the wrench, hose and jar off my hands... hose swinging back and forth, shooting fluid all over the place, me crawling under to find the wrench, i finally turned the valve and shut it off, it was still shooting a 5 ft stream. 7. Cleaned the mess, filled reservoir again, this time open valve VERY VERY little.. went fine.. filled reservoir. I just run out of fluid, 2 liters gone by now. got to get some more. 8. Got in the car, pumped brakes, turn the key on, all systems are go, went fine.. diag good, started the engine, moved the car back and forth just a little, good deal.. 9. shut it off, went inside to clean up. 10. got back in, started the engine, took off to the store, so far so good. Smooth, strong, good brakes. Engine strong, roaring... good 10b. Just 3 miles later, ENGINE FAULT SYSTEM ... SERVICE NEEDED...pulled over, checked codes.. got two codes E046, E055. And of course smoke everywhere, brake fuild was high temp Prestone, Dot 3, but on the manifolds, it toasted and smoked and smoked.. 11. Let it be said that on Nov 14, 2002, Allante xxx445 gain awareness! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 12. Got to the store, bough a GALLON of fluid this time. Can never have too much! 13. Returned to car, started engine... LIGHTING SYSTEM .. "left stop light and left turn signal OUT!" she is trowing a tantrum... ! 14. Got home. She drove like a rocket, no problems (but DIC errors still there). Smooth, powerful, steady. Even burned a little rubber, she didnt complaint.. Nice ride.. But DIC errors are still there. Is she thinking i am going to pack her up for the winter? or worse? =================== originated by allantesource It is also a good idea to periodically check the run time of your ABS pump to repressurize a completely depressurized ABS system. You can check the condition of your ac***ulator at the same time. First, with the ignition off, depressurize your system by pumping the pedal all the way to the floor 25 times (full and deliberate pedal applications, not quick jabs). At some point, you should experience a change in the feel of the brake pedal. Make a note of this. Then, without touching the brake pedal, turn the ignition on, and time how long your ABS pump runs before shutting off. It should be 30 seconds or less. If it runs longer than that, most likely it is failing, and should be replaced promptly. The pump relay should be replaced at the same time. After the pump has shut off, you can check the condition of your ac***ulator. Turn off the ignition. Then start depressing the brake pedal again, but this time count the number of pedal applications before the pedal comes up off the floor and the feel of the pedal changes (it will become rock hard). This should be about 15 applications. If it is less, then your ac***ulator is weak and should be replaced. If you continue to run with a weak ac***ulator, it will cause your pump to work too hard, and possibly it could fail prematurely. That was back in '03 .. some of the D.I.C. errors become on/off permanent nuisances to this day. =================== This is what allantesource recommends and I have every intent to follow - LET ME ADD that BEFORE this is done, you MUST DEPRESSURIZE the system by turning OFF the key and then pumping the pedal until it goes to the floor - also, I edited (my edits in parenthesis) the quote into two sections, powered and manual: by allantesource (depressurize system) First the ABS pump gets bled, key on, until bubbles are gone. A clear hose gets attached to the pump bleeder screw, the end of this hose submerged in a jar with about an inch of clean brake fluid in the bottom. Open the bleeder screw on the pump, and let it run until it clears up. About 30 seconds at a time is all you should let the pump run. (turn OFF key, shut off bleeder screw) Let it rest for a minute, then another (open bleeder screw then turn pump ON) 30 seconds, etc. Generally three cycles of this will be enough. Keep the reservoir full, within 1/4 inch of the full line. Next you bleed through the bleeder screw on the master cylinder. Again, have a clear hose on the bleeder, end submerged into a glass jar with clear brake fluid. Open the bleeder screw. Turn the key on, and let it run until fluid is clear of bubbles. 30 seconds on cycle, then rest. (AT THE WHEELS) I will walk you through manual bleeding, which I what I do. It requires two people. This portion is performed with the key off. The order of wheels is RR, LF, LR, RF. Attach clear hose to bleeder, end submerged in glass jar with 1" of brake fluid in it. Have an assistant pump pedal a few times, then hold, and open bleeder screw until flow stops. Tighten screw before pedal is released. Repeat as needed until fluid is clear and there are no more bubbles. Keep an eye on the fluid level in the reservoir. This whole portion of the bleeding is with KEY OFF. |
by allantesource As Zal found out, it is IMPERATIVE to depressurize the system first before bleeding the system. Also, the easiest way to get fluid out of the reservoir is to drain it into a small funnel and collection container placed below the front corner of the reservoir. The fluid change procedure is reprinted below, in two sections. Simplified brake fluid change procedure Regular brake fluid changes for all 1987 through 1992 Allante's with the Bosch III ABS system will significantly improve the life of these systems. By not changing fluid, over time old brake fluid loses its anti-corrosion properties. It appears to start attacking the metal in the system, especially the aluminum housing. Then crud starts to form. This crud works it's way into the sealing area, and starts abrading the seals. As internal seal leakage increases, plausibility fault codes start appearing, turning on the red brake warning light. Once the damage has occurred, the ABS system must be replaced to correct the error conditions. For a couple years I have been following a simplified brake fluid change procedure. We have also changed the brake fluid in a number of local club members' cars following the same procedure. I thought I would pass it along, to get more people to change their brake fluid. Doing this annually is a very good idea. Start by depressurizing the brake system by pumping the brake pedal 25 times with the key off. It is not a bad idea to unplug the ABS pump after doing this. Put a piece of cardboard under your car, under the master cylinder area to soak up a small amount of fluid which invariably will drip down. Next, remove the air duct between the airbox and the throttle body. With a jar or can and small funnel underneath, pull the hose off the lower front corner of the brake fluid reservoir. Allow the fluid to drain completely. If the fluid is really black, the reservoir really should be cleaned. The reservoir can be removed from the master cylinder as follows. Disconnect the hose(s). Insert your fingers under the front, and pull up. There are three "feet" or ports on the bottom of the reservoir, which will pop out of grommets in the top of the master cylinder housing. Immediately clean off the area under the reservoir, to make certain no foreign material gets into the openings. Next, remove the screen from the reservoir. Any of a variety of solvents can be used to clean the inside. It may take a couple hours if your reservoir is really loaded. Brake pad cleaner, lacquer thinner, TSP, and degreasers will all work to some degree. I purchased a used ultrasonic cleaner specifically for this purpose, which works well. After cleaning the reservoir, it must be THOROUGHLY flushed with clean brake fluid to remove any trace of cleaning solvents and moisture. Then reinstall on the master cylinder, and reconnect hoses. Refill with clean brake fluid, preferably DOT 3. NEVER use DOT 5, synthetic silicone brake fluid. Some brake fluids are DOT 3 and DOT 4 spec. Those are OK too. Next, take a clear piece of hose, about 2' long, 3/16" ID, and attach it to the bleeder on the ABS pump. Submerge the end in a collection jar. Plug the ABS pump back in, and turn on the ignition for about 30 seconds. Watch the hose for bubbles, and the clearing of the dark color from the fluid. Repeat several times as necessary until bubbles are gone and fluid is clear. A few very small bubbles are OK. Do NOT open bleeder screw too far. When you are satisfied, with pump off, close the bleeder, and refill reservoir. Next, attach the clear hose to the bleeder fitting on the side of the master cylinder, pointing toward the right side of the car. Open the bleeder between 1/2 turn and a full turn. Submerge the end of the hose in the collection container. Turn on the ignition, and run for 30 seconds. Then shut off and wait a minute or two and repeat as necessary until fluid is clear and no bubbles are present. Then shut bleeder, remove hose and collection container. Refill the reservoir. That's the end, other than reinstalling air duct and cleaning up. What you have done is to replace all the fluid in the working portion of your ABS system. IT IS IMPERATIVE THAT WHEN BRAKE PADS ARE REPLACED AND CALIPER PISTONS NEED TO BE COLLAPSED THAT BLEEDER SCREWS MUST BE OPENED AND OLD BRAKE FLUID MUST BE DISCARDED. IT MUST NEVER BE FORCED BACK INTO THE ABS SYSTEM. THIS IS THE CASE WHENEVER YOU ARE REPLACING YOUR BRAKE PADS, WHETHER OR NOT YOU HAVE FOLLOWED THE ABOVE PROCEDURE TO CHANGE YOUR BRAKE FLUID. |
