Traction control light
Hi all.
I have a 1995 Fleetwood Brougham and the traction control light stays on constantly. Any suggestions on what the problem may be? Other than that the car runs and works perfectly. |
After doing some cleaning I decided to remove the battery cable and leave it off for a bit while I did something else. I reconnected it thinking that it might turn off and nothing. It's still on.
I checked the codes and I found nothing. Any ideas? |
I have a similar problem. I have Traction Control light and ABS light that stay on.
I'll keep checking to see if you get an answer. I get the feeling that this is a common problem with these Cads. (I have a '99 deville) I've read more articles on this. How is your car running? Mine was OK for a while but has started missing and the tranny seems to be acting up. Did you check for codes? I got TCS C1242 current and TCS C1255 history. Still trying to figure out what that means. Have you done anything else to fix this? I'd like to know what helps. I am not looking forward to putting all sorts of money into this car. |
Hi ChevyGranny
The car is running fine. I'm getting about 22mpg with all around driving. I'm taking it to the shop this week to have them take a look at it. Hopefully it won't be to pricy. |
