429 engine block coolant drain plug locations
Old 05-16-2018, 02:16 PM
fmeili's Avatar
Default 429 engine block coolant drain plug locations
Hello,
does someone knows the exact locations of the (2 or 3?) engine block coolant drain plugs. Maybe a picture?
I want to do a COMPLETE coolant flush for a 1966 Cadi.
Thanks a lot in advance.
Frank
Old 08-21-2019, 11:59 AM
Schurkey's Avatar
That info will be in the service manual.
Some Buick engines do not have coolant drain plugs.
Every engine I've found drain plugs on, have been low on the side of the block. Pontiac used 1/8" pipe plugs, most everything else is 1/4" pipe thread.
Once the plug is out, you may have to poke a Philips screwdriver through the ac***ulated "crust" of deposits before any coolant will drain.
On engines I care about, I install brass drain ***** instead of the iron plugs.
Old 08-28-2019, 01:49 PM
Schurkey's Avatar
Charming censorship. If I'm logged-in, there's only one word censored. If I'm not logged-in, there's two.
tommy
09-24-2011 06:23 AM
greg2169
04-17-2011 07:37 PM
majbarron
11-11-2009 06:21 PM
wgoodlin
01-29-2009 01:31 AM
jrm347
05-17-2007 08:15 AM
Quick Reply: 429 engine block coolant drain plug locations
