the foxpaw, not-inmortal 4T80-E transmission ...
foxpaws I went to get the fluids changed out of my car when I bought it they said not to do the tranny fluid - at the dealership - they did the rest of them (coolant, brake) but not the transmission - should I go ahead and have them do it anyway? I am pretty sure I have the old bullet proof 4T80-E in my '93 if you click on #2 of this https://www.cadillacforum.com/m_6733/tm.htm then go to the 2nd page you will find this https://www.cadillacforum.com/m_6036/tm.htm |
RE: the foxpaw, not-inmortal 4T80-E transmission ...
Hey, I did the coolant, with no flush - and the brake fluid - when I got the car, I was just wondering about the tranny fluid they didn't change out - so I guess that is a yes on changing out the transmission fluid at 60,000?:eek:
ORIGINAL: foxpaws Hey, I did the coolant, with no flush - and the brake fluid - when I got the car, I was just wondering about the tranny fluid they didn't change out - so I guess that is a yes on changing out the transmission fluid at 60,000?:eek: My harsh driving habits have me at around 25,000 .. cheap maint .. trani O.H. is what? $1,500 to $3,000 ? Quick 30 min job, that i hear even a girl can do .. ohhh, forget it .. broken bits of nails are not friendly to gears. Allantes take a bit longer since they are so damn low, i cant drive mine onto my ramps .. jacks only.. There is this practice that if one runs to the performance limits of a car, any car (at the track of course), BOTH engine oil AND trani fluids should be changed the following day. Some extend that to the POSI-traction gears and the transfer case gears when you have those (4x4). There is nothing like silky clean fluid and new filters to extend the life of such a workhorse as a trani. IMHO. The links were meant to address the Flush vs DRAIN. Some cars (which I got) allow you to disconnect the line to the TRANI OIL COOLER (your '93 has none of that) and literaly pump/DRAIN much more than dropping the pan. However, your 4x4, may have one .. may. ============ I am pretty sure I have the old bullet proof 4T80-E in my '93 . |
