filled transmission fluid up when car was off
I put transmission fluid in when the car was off then I saw that it was supposed to be on l turned it on and liquid was bubbling up to the top. do I now need to get it out?
Cause when I check it with the car off its in the cold zone so it looks good but I don't know if I should take it out and then recheck when engine on at idol. |
normally if adding fluid to full mark with engine off it is low when started. If with engine idling after cycling shifter from park to L and back to park. Stopping momentarily in each gear if fluid level is over full mark. You will need to drain some out until level drops into hash marks indicating full.
