Do I Need A New Overdrive or Transmission?
https://www.cadillacforum.com/micons/m5.gif My 1994 Cadillac Seville SLS won't shift into it's final gear. It almost sounds as if it "red-lines" (the sound you hear when you don't shift in a manual transmission). Could this be the overdrive or is it the transmission? https://www.cadillacforum.com/micons/m5.gif
[sm=helpout.gif] |
RE: Do I Need A New Overdrive or Transmission?
Check the fluid level and condition first. Fluid should be a redish pinkish colour and not burnt smelling. If it looks Ok and it is low top it up and see how it runs after that.
welcome to the Forum! Cadillacgirly............ Katz is the guy to talk with....... enjoy the Forum.... look around and get yourself counted in Cadillac Demographics, under Off Topic...... later
rickyd |
ORIGINAL: CadillacGirly https://www.cadillacforum.com/micons/m5.gif My 1994 Cadillac Seville SLS won't shift into it's final gear. It almost sounds as if it "red-lines" (the sound you hear when you don't shift in a manual transmission). Could this be the overdrive or is it the transmission? https://www.cadillacforum.com/micons/m5.gif [sm=helpout.gif] four other things . 1. welcome 2. https://www.cadillacforum.com/fb.asp?m=12170 and 3. https://www.cadillacforum.com/m_7219/tm.htm 4. codes? https://www.cadillacforum.com/m_9792/tm.htm |
Thanks! I'll be sure to come by if I have any other questions!
Jamie Ryan |
ORIGINAL: CadillacGirly Thanks! I'll be sure to come by if I have any other questions! Jamie Ryan how is the transmission doing ? |
