trichey73 |
04-26-2014 10:13 AM |
'99 Deville-No Fourth gear
ok, I have recently purchased a '99 50th Anniv Deville. The ONLY code at the DIC is a IPC U1255(Class 2 comms failure). Shifts are all good and smooth, except no attempt to shift up to Fourth and also when manual downshift to Second, the car just "Free Wheels". I have REPLACED the fluid/cleaned scavenger filters, replaced the Lower Valve Body (complete), and Fourth gear servo and piston pin assy. old fluid was very dark, almost black (Rut Roh). Also, NO other codes, checked all fuses(front and back), and the Valet switch is NOT turned on. I am at wits end, please help! Thanks.
