85 deville
I got an 85 deville n the 3 bolts on the a/c pulley(I'm guessing its the a/c pulley) worked themselves loose sum how. luckily I was drivin to advance auto parts and as soon as i got to a parking spot the pulley came off completly shreddin the belt. Bought a new belt, bolted the pulley back on, installed belt, drove home, cept now it makes a really bad whining sound. I dnt want to take it 2 the shop and pay for sumthn i can fix myself. sum1 tell me wht the hell is tht noise thts drivin me up the ******* wall.
RE: 85 deville
ORIGINAL: L99X I got an 85 deville n the 3 bolts on the a/c pulley(I'm guessing its the a/c pulley) worked themselves loose sum how. luckily I was drivin to advance auto parts and as soon as i got to a parking spot the pulley came off completly shreddin the belt. Bought a new belt, bolted the pulley back on, installed belt, drove home, cept now it makes a really bad whining sound. I dnt want to take it 2 the shop and pay for sumthn i can fix myself. sum1 tell me wht the hell is tht noise thts drivin me up the ******* wall. It be good if you identify which pulley we are talking about. Another suspect is the water pump .. that impeller pulley of the water pump cant take much abuse, including the failure of a belt. all of it, easily done by anyone with tool skills. your car is over 20 years old .. you may want to read some of these threads .. will save lots of $$$ in the long run. The BEST car Cadillac ever made is the .. you get to pick. https://www.cadillacforum.com/m_9438/tm.htm MY Cadillac has more miles than yours thread .. Lets get the 400,000 mile cars. https://www.cadillacforum.com/m_12353/tm.htm CODES .. Pulling & understanding CODES .. we need CODES to help you. https://www.cadillacforum.com/m_18197/tm.htm https://www.cadillacforum.com/m_17425/tm.htm https://www.cadillacforum.com/m_11904/tm.htm Community Services: Auto parts, Vehicle Taxes, highways cams, picture capture, Corp 800 #’s, unique shipping services .. etc ... take a look. https://www.cadillacforum.com/m_9880/tm.htm Average age of our Cadillac owners .. where everyone says they are 23. https://www.cadillacforum.com/m_931/tm.htm Why you should change to coolant the day you buy the Cadillac. https://www.cadillacforum.com/m_7193/tm.htm https://www.cadillacforum.com/m_7388/tm.htm Transmissions or Engines - why you do NOT FLUSH the 4100 & 4500 drive trains. https://www.cadillacforum.com/m_6036/tm.htm Cadillac GM e-ghosts electric problems, intermittent codes, etc. https://www.cadillacforum.com/m_6068/tm.htm Help from our TECHs ? You really want to read this. https://www.cadillacforum.com/m_9792/tm.htm Cadillac TECH FAQ MENU .. pull up all the FAQ topics https://www.cadillacforum.com/m_6733/tm.htm Cadillac Technical FAQ section .. everything Cadillac https://www.cadillacforum.com/forumid_64/tt.htm Cadillac Allante TECH FAQ .. things that the car needs often, owner’s manual, etc. https://www.cadillacforum.com/forumid_83/tt.htm The Cadillac Allante Pub - discuss, argue, and laugh .. Allante not needed to jump in. https://www.cadillacforum.com/m_21055/tm.htm Allantesource.com Allante PROCEDURES MENU .. issues that few know how to handle https://www.cadillacforum.com/m_18287/tm.htm Hobby Corner .. Hot wheels, trains, whatever .. https://www.cadillacforum.com/forumid_60/tt.htm Cadillac History .. The real McCoy, from day one. https://www.cadillacforum.com/m_6356/tm.htm Welcome to CadillacForuM.com |
RE: 85 deville
Ithink the pulley you refer to is the one on the waterpump. Once it comes loose it has worn the bolt holes in the pulley. The whine noise could be that pulley not aligned. Remove that pulley and verify holes are perfect. If not, replace it and install star washers on bolts along with red locktight.
RE: 85 deville
Amazing what locktight,star washersand sum belt spray can do. I can barely hear the engine now. Also rechargd the a/c, bought a self recharge kit at A.A.P. and 2 cans later my a/c was blowing cold w/o ne leaks. Thnx 4 the help!
RE: 85 deville
Please put year and type of Cad in your signature profile. Thanks for the follow up!
