1994 eldorado stuck in 2nd
My 94 eldo was stuck in 3rd, P029 solenoid code.
I replaced the solenoids, filter and installed the L-Bracket. Put it all back together and now it is stuck in 2nd? Any Ideas? |
Any codes set now?
Will it do anything different if you manually shift it(with the shifter)? |
Alan
Do you have any cods now? if not it sounds like the spring fell out from behind the shift solenoid. only one is spring loaded.
