torque specs
need torque specs for a headgasket job i'm doing on my 2001 cadillac deville dhs.need cam timing
local library
I went to my local library and printed out the info from their "ALLDATA", which is the factory manual on-line for free. I also noticed there is a TBS bulletin out that gives a revised torque angle on the last step, it was only a 10 deg. less difference (if I remember right) from what it originally was and of course I did not come across this TBS until a week after I had torqued my heads down. I would suggest checking out your library, I was able to print out everything I needed for my engine rebuild.
